Premature ABS lock-up
I amd running 35" tires with a 4" spring lift. I have repositioned the LSPV.
Lately I have been noticing the front end seems to lock up and activate the ABS system to for the wheels to turn, much more prematurely that necessary. It seems to happen for an instant just before I come to a complete stop, sometimes when going slow and the wheels turned all the way to one side, or on when breaking on wet roads.
The ABS in the front to seems be overly sensitive. does this mean I need to fine tune the positioning of the LSPV? If the front end is locking up, does that mean the LSPV needs to be tapped up or tapped down?
Likely something else unrelated to the ABS?
Sounds like one sensor is dirty, sensing that wheel stopped. It's ignored 'till the rest of the wheels are almost stopped, then ABS kicks in. I fixed it by pulling metal fragments off the magnetic sensor.
x2 what Scott said, I had front axle work done and immediately afterwards my abs system started kicking in pulling up to every stop sign in town. The ABS Sensors in the front axle needed cleaning. No problems since.
This may sound like a stupid newbie question, but here goes.
Can the ABS sensors be pulled for cleaning without partially disassembling the axle? I've looked at it and searched here but haven't come to a definitive answer.
Yep, they are held in the top of the knuckle with one bolt.
And the rear is also held in by one bolt. But if that bolt snaps off instead of threading out, you have to pull the whole brake assembly apart to get to it. :mad:
Yep, all four. Just follow the lone wire going into the hub, hard to miss it. I don't remember having to take off the tire, not sure about the front though, I had it apart anyway at the time.
I LOVE THIS FORUM !!!
(Good thing we are not all on the trail together at the same time seeing how we cannot stop !!)
My brakes work great on the trail as long as it's in low range or if the center diff is locked (abs disabled).
Hope to get them cleaned tomorrow...
Someone ought to document this with pictures for future reference. . .:hhmm:
Honestly, it's one bolt and a wipe with a paper towel. Unless you take a bunch of pics of tire removal, it's pretty straight forward.
One of my sensors was cracked, so had to replace them. They only come as a set, trust me on that, and that includes the harness. I have heard that the harness can be damaged and cause the same problems, so you might want to see if a rock caught a wire.
The new sensors were in a potted plastic housing, and the original ones were (looked like) aluminum.
If you have lots of metal chips on the sensor magnet, you might want to ask where they came from.
Be sure to pull the ABS sensors before removing an axle, or you will most likely ding the sensor.
I just pulled the ABS fuse for a few months until I figured all that out. Cars have been driving around with out ABS for 50 or so years, so I thought a few months would not hurt. Worked fine.
Jack Nichols, 1993 LC, 2" lift
this will also happen if the abs sensor is not seated correctly, some times the rubber O ring can come out of its seat and prevent the sensor from siting flush on the knuckle
