I’m going to be taking a trip to Colorado (Dolores) in July and I thought it might be a good idea to do a little pre trip inspection. I am posting my checklist ideas to see if there is anything I am forgetting.
I will be towing a boat to Colorado and also I will be doing some wheeling while there.
Here is my checklist:
Jack front of vehicle, check wheel bearings for looseness with the 12/6 method.
Check steering for looseness with 9/3 method.
Remove front wheels.
Inspect front pads (new < 1000 miles ago)
Torque caliper bolts.
Torque knuckle trunion bolts/nuts.
Replace front wheels and torque lugnuts.
Jack rear of vehicle.
Check for wheel play and remove rear wheels.
Inspect rear pads (new ~5000 miles ago)
Check Adjust parking brake
Replace rear wheels and torque lugnuts.
Torque receiver hitch mounting bolts.
Install hitch and torque ball nut.
Check differential and t-case levels.
Grease u-joints.
Check tire pressures including spare.
Check under hood fluid levels.
Check air filter (new last oil change ~2500miles ago)
Check lights.
In anticipation of this trip, I have done the following maintenance:
Complete Birf job (<1000 miles ago)
100 series pads and new OEM rotors (<1000 miles ago)
New Brake hoses (<1000 miles ago)
Flushed brake fluid (<1000 miles ago)
Drained and filled the differentials, transfer case and transmission (<1000 miles ago)
Repacked the rear wheel bearings and replaced the seals (<1000 miles ago)
Fuel filter, plugs, wires, cap, rotor, (~2500 miles ago)
The weekend of the 23rd I’ll be changing the engine oil and filter.
Am I missing anything?
Thanks,
Dave
Grease u-joints.
Check lights.
Thanks,
Dave
