If people are interested, this thread is a place to post and share oem part numbers for pre-1969 40 series.
Being new to early 40s I am still trying stubbornly to buy OEM parts the way I do with the 80. Dealers do not have part numbers before 1969 but many oem parts are still available. Unfortunately, unless you have an old parts fiche or keep your old parts bags and invoices you do not know the pn#s. I am going to keep hunting for a parts fiche but until then...
So far, the following are all for my 1966 and as of posting this is their availability status. If it says "good" you can order it
Idle mixture sd40 spring: 21723-21030 - good
Carb float sd40: 21209-60010 gone
Carb rebuild kit (SD-40): 04211-60086 good = $28
Belt 90916-02014 still good but switches to new pn# I forgot to note
82 c Thermostat 90916-03014 = good
Speedo shaft o-ring--little 90301-09010 = 90301-09017 good
big o-ring 90301-18018 good
Visor RH 74310-60011 now 74310-90300 = still good
LH 74320-60011 now 74320-90301 = still good
PCV valve 12204-60020 -- now - 12204-60021 : f listed so discontinued
Tie Rod Ends (from later 40s but compatible and beefier)
45045-60H00
45046-60H00
45046-60H02
45046-60H03
45047-60H00
all good
45045-60H00
45046-60H00
45046-60H02
45046-60H03
45047-60H00
all good
