PPH done.. but now have a 330 code?
Wayne
Bought by His blood, kept by His power
Middleburg, Florida
I've had the parts to do the PPH replacement for more than two years and kept putting it off. Well, she finally blew when the wife driving. She was close to home, reacted quickly and didn't over heat anything.
The job was everything everone has said about it....... a pain in the a$$. I used NAPA silicon hose and the continuous tension clamps, so, it should be good for a long time.
I did get coolant all over the wires and connectors in the area underneath when I pulled the old hose out. Now I have a 330 code (knock sensor). Not sure why, except it got wet. Any suggestions or comments?
Wayne S
I've reset the code four or five times and she keeps coming back.
Wayne S
Bad connector (search for it, I recall a few mudders have had just a bad connector that they fixed), or a bad wire or bad sensor? Someone who has experienced this will chime in. The FSM says for anything with a connector, one of the first things you can try is to disconnect the connector and then reconnect it. If you can get some CRC quick disconnect cleaner (most parts stores carry it), you could also spray both sides of the connector well to clean them up, let it dry a few seconds, and snap it back together to see if that does it.
Here is a link to one thread
https://forum.ih8mud.com/80-series-tech/11780-rear-knock-sensor-location-cruiser-dan.html
I have no clue what a 330 code is, but I will say that the Neutral Safety Switch is in a prime position to be drenched from a PHH blowout.
You could have knocked a wire off the sended. They are pretty fragile as I recall. I hope for your wallet it isn't that!
Good job on the PHH. I thought it was a huge hassle too.
Check to make sure you didn't break the end of the Knock Sensor off. I did when I did mine on my LX. I had to glue the sender back together. Managed to break it again when I was doing the HG. Couldn't glue it this time, had to order a new one. Ouch.:crybaby:
On my Landcruiser, I removed the sensor before I started the PHH process. See I can be learned.:hillbilly:
Good luck
Jack
