Powersteering options for 70
876 Cruisers
KZJ70/FZJ70/HJ47/HDJ80²
Jamaica
Good day all,
I'm trying to figure out something with the power steering boxs for the 70 series LC
When I bought a 1990 PZJ70 it came with a powersteering box that had a forward facing pitman arm.
I currently have a rear facing pitman arm ps box on it currently.
Does anyone know why it came with 2 different options?
Thanks
Dan
I'm not sure . When I look at the diagram it shows me a forward facing pitman arm
Or I know the "prado" 70s use a forward facing pitman arm steering box. I'm wondering if something happened and they tried fixing it with one of
Wasnt a 60 series box though as I have a 60 box laying around and they look different. It definitely looks like a 70 series box. I'm thinking maybe a 70 series prado box
Yes. That's the steering box I took off. A forward facing arm
The correct mounting holes in the frame will be sleeved.
Photo credit to @Shes Mad
The ps box was bolted in the correct holes. With the correct shaft and all. The only thing I had to do was change the ps box to the rear facing pitman arm box. Looks the same and all just was a forward facing pitman arm. So I thought maybe some of the HD 70s came that way but I'm gonna assume someone swapped it to a LD 70 ps box.
Wow, I'm surprised that even worked. I would've thought the spring shackle to be in the way. Any chance you have a picture of the old set-up?
Edit: found pic of stock set-up...
I dont have a picture actually. And when I bought the van it wasnt even driving. No engine was in it. No front differential. I dont even think there was a drag link on it. So maybe they were In the process of fixing it up or someone swapped out the old box for the box that came on it
