Power window problem..
The left PS window only works at the passenger door. The main control switch doesn't work it. I tried fixing the master panel switch by cleaning the contacts (didn't change anything). Then I picked up a used master controller from TAP recycling but still no change. So I then tried an extra door wiring harness (PS door) I had and that wasn't the issue either. All of the other windows work fine from the master and at their local switches.
Any ideas as to what might be causing it and what I might try next?
window problem
You are making this entirely too hard for yourself. Take a multimeter and find out where the voltage is dropping first before you replace anything. This way it won't be a wild goose chase.
Ahhh..well i downloaded the FSM and now will teach myself how to do electrical work the RIGHT way..
although now I am regretting having an analog vs. digital Multimeter!
Fixed..it was the PS door switch..swapped the other PS switch in and now the master can control the window.
