Power Window motor
Many will not like this but I bought one off ebay. Bolted right to the factory mounting points but the connector was not the same. I used a screw drive to slide the spade connectors out of the plastic piece on the new motor and slide them into the cruiser connector and electrical taped it. It worked and it only cost $50.00.
does it matter which window? will motors from a 96 work for yours?
I would certainly like to know the answer to that myself. when I opened up the door, I was pleased to see lots of steel gears, I don't know if the motor itself has a steel gear, but I'm guessing it does. What was weird to me is that the motor is slim-line and looks way small. I've seen junker hundai's with bigger motors.. I went COMPLETELY through the drivers door switch component today. It had a lot of black/burned places, but that was not the culprit, some of those springs can be tricky. my dealer wants about 275 for the switch plate, and 350 for the motor. anyone have any experience replacing/purchasing these?
a
There is a plastic gear inside the motor that can strip. Someone (IdahoDoug?) posted a FAQ on how to R&R it.
So is the motor not functioning at all, intermittent, or just slow? If it's intermittent, then it might be the wires connecting it to the fuse box (there's a couple junctions where it can corrode). If slow, it could be the window run or those connections.
You can prob. find an auction still going like this one...
1
eBay Motors: TOYOTA LANDCRUISER NEW WINDOW MOTOR 91 92 93 94 95 96 (item 380070780621 end time Oct-29-08 10:15:50 PDT)
I paid about $320 for a motor just recently....so that price is in the ballpark.
a
I'm telling you, forget the dealer, forget eBay, and forget the junk yards. My recent search yielded a brand new (not rebuilt) window motor for my driver's door (this is just the motor without the arm assembly) for about $60. Plus, it comes with a lifetime warranty and there is no core deposit. The only problem is, I can't recall if it was either Autozone or Advance Auto Parts. Just check their websites and you should be able to find it or give them a call. Brand new motor + lifetime warranty + no core deposit + only $60 + available at national retailer = NO BRAINER!
Are the window motors Land Cruiser specific or can you take a motor from another Toyota and drop it in? I thought someone on here used a Camry's window motor? Might be cheaper to find if that's the case. I need one for my front passenger. Luckily it went out when the window was fully closed. Maybe that's why I've ignored it for 2 years. :doh:
You're right!!! :idea: And it's AutoZone for $63. Sweet! :cheers:
I have grown weary of Autozone.
I used to get brake pads because of the lifetime warranty. When I was a kid, I didn't mind changing the brakes every 10,000 miles. Now, I would rather pay twice or three times as much for the OEM or Wagner Premium, and get 40 to 50k miles out of em.
They have a lifetime warranty, but you get what you pay for. :meh:
I hope that motor does last as long as your rig, but in my experience, you will be using the warranty. It wont cost you anything except your labor, and that might be a great deal for you. Good luck.
This is what I did with my 95 when I had it. I had a 96 4runner at the same time, I was able to source a use 99+ 4runner driver window motor for really cheap. If I remember right, I actually somehow make it work with the 4runner motor.
It may not be the motor itself. I don't know that the motors actually go bad that often. But what does go bad is the plastic gearing inside the motor mechanism. Especially if the window gets stuck in the run. If you can get the whole assembly, then you get all new gears, but if you just get the motor and have to swap them over, it may not solve your problem.
Also a good cleaning of the motor and internal contacts might be all that is needed, if in fact it's just the actual motor.
If you're smacking something and it works, it sounds to me like a dirty contact issue, either in the switch or the motor or the window is hanging up in the run, which is pretty common.
Here is my my write up on swapping out the plastic gears....
https://forum.ih8mud.com/80-series-tech/198117-power-window-repair-w-pics.html
I have one from a 1994 with 43K on the clock. PM me an offer if interested.
