Power window delay problem
Provo, Utah
My truck has recently developed a strange problem. My driver side front window won't roll up or down like it used to. It won't work at all unless I use the automatic window function. Even then, when I push the auto-down or auto-up function, it takes a good 20 seconds for the window to react. I am the one who did the auto-up mod on the window and it has worked great for years. I am baffled by why there would be such a long delay between me pushing the switch and the window reacting. All the other windows work fine. Any ideas?
Remove the switch and check the wiring harness. You can also open up the switch and check the contacts, they get fairly dirty from normal use. FWIW, mine acted similar until completely crapping out. I replaced it with a SwitchDoctor part.
I already took the switch out and cleaned/checked the harness and cleaned the switch and contacts with electrical parts cleaner and a needle file. The weird thing is that it only acts this way occasionally. It looks like a new switch may be in my future.
