Just FINALLY finished my p/s rebuild. What seemed so simple turned into a nightmare. The p/s pump and hoses were leaking and making a mess, so thinking it was fairly simple like my wife's CRV's pump which I rebuilt last summer, I bought a rebuild kit ($68 not including the seal between the pump and the motor) from Toyota and dove in. Day 1: It was fairly easy to get the pump off (remove battery and holder, oil filter, disconnect some wires that were in the way) but while dismantling the pump I damaged the bushing (not shown on the FSM) inside the pump. Smoothed it out as best I could but then thought it might be better to buy a new pump, so I did ($340 inc. tax). Day 2: Well as long as I'm in here might as well replace the hoses to the cooler, they were all hard and I couldn't get them off, so I cut them. Bad move as nobody sells 10mm hoses and they have to be replaced with 3/8 inch which are hard as hell to slide on. Day 3: Couldn't get the new hoses on as its really tight down there, so I took off the radiator hoses and fan and fan shroud after spilling most of the coolant on my garage floor and driveway (along with p/s fluid). After fiddling around with lots of blue words finally got the new hoses on. Day 4: Mounted the new Toy high pressure hose ($300) on had one hell of a hard time getting the end to start on the p/s box. Tight in there you know. Grease and crap everywhere. Day 5: Finally all back together. Added fluid changed engine oil, added distilled water to radiator. No leaks. Started engine, p/s fluid spayed everywhere as I'd forgotten to replace the p/s reservoir cap. Put on cap and got the air out of the system and lo and behold it all works great!
Conclusion: Working on cars is fun (ha, ha) expensive and occasionally satisfying. When it's all done.
Ned
Ned
