power steering swap
If you are still going with push/pull steering -- non Hy-steer
old style ps box ( push/pull, solid axle truck).
ps pump
all the hoses
bracket to mount pump to the engine
Total price: 25-50 at you pull yards in colorado, I have done two conversions
IFS means the Hy-steer option.
High steer parts
new style box ( ifs truck)
ps pump
all the hoses
cut the tower off the front axle and clean it up.
Same 25-50 plus the hy-steer parts, have this on an 83 crawler.
does anyone know what i might need to swap over my steering componants from push/pull to ifs steering on my 80 model pickup?
OK, you want to go from manual p-p (stock) steering
to power IFS steering?
The IFS box is used for x-over steering conversions.
If so you need a x-over steering kit (AllPro, Marlin, etc), power IFS steering box, the hoses, PS pump and mounting brackets, and PS resevoir.
If you mean you want to keep the stock p-p steering you need the same stuff but a stock type PS box.
Where exactly do the hoses go on push pull box, I can't seem to see any in mine. I see what looks like a breather up top.
Either PS box, p-p or IFS type has ports for 2 hoses.
One hose (low pressure return) goes to the resevoir.
The other (high pressure) goes to the PS pump.
Another hose goes from the resevoir to the pump.
