Power Steering Pump Leak??????
Rock Hill SC
I picked up a slight leak on the way home. I think it is the PS pump. What do you guys think?....I bugs me to no end to have a leaking vehicle.....must fix:bang:
Mine looks like that too. Pretty common I think.
Rebuild kit from cdan is around $50 iirc and it's well documented on
I'd how to do it. Pretty easy. I think I used my neighbors home made press for something that made it a little easier. Replace high pressure hose and return while you're at it. No leaks since. Good time to handle starter contacts and phh while you're down there.
Just be careful when you put it back together. Don't knick the gear at all or you will be left with a nasty sound that scares the heck out of you because you think you blew something.
Side Note: Thanks to John at SDTTrux for diagnosing that little issue I had. :hillbilly:
