Power Steering pump leak
Nairobi
Website
www.bushwings.org
Heya! Anyone have experience dealing with a leaky power steering pump? I've got a '95 HDJ-81 with the 1HD-FT engine. The pump on the engine leaks, probably a gasket I suspect. Also the resevoir always seems to have oil on it...just a little like it's weeping from the filler cap.
Thanks!
If you are leaking up top it's likely the seam where the top of the reservoir is crimped on. Common problem. ATF seeps out and gets blown back all over everything. I have tried sealing with goo but ended up biting the bullet and buying a new one for $200
The lower end of the system tends to drip is at the suction port at the bottom of the PS pump.
$2 Oring and a smear of FIPG on the flange for good measure and it's fixed.
