There were two basic GM saginaw pumps, one had a keyed pullet shaft and threaded for a nut. The pressure fitting used a flared line.
That style continued to about 1974 when it was replaced by the style with the press on pulley like yours. The press on pulley is still in use but a change was made in about 1980 to metric. The pump itself didn't change but the pressure fitting went from a flared fitting to an O-ring fitting and some of the threaded holes went metric somewhere inthe early 80s. The layout of the pump was the same . There were variations in the return tube. The return on yours was consistent with GM sedans like the Caprice or Camaro. It looks like you have a flared pressure hose so try looking for a 1978 Caprice pump. Your return looks like it's been finessed a bit so it could also be from that year pickup truck. The truck return points more toward the block while the sedan versions point more forward
