I think am getting excessive pressure to the return reservoir. The fluid rises up and almost out of the reservoir with the motor running.
I am getting excessive noise from the pump. Its ticking and churning. It does this with both the old and new pump.
I bleed the system many times doing both the FSM method, Mud method and my method (pull the EFI fuse and crank the motor with the return line removed, fluid runs through the system and into a container. Keeping the container full all the time).
When I fill the reservoir with oil, with the return line removed, fluid (ATF) will flow out the return line, this is with the motor off.
Should this happen?
Could anything in the gear box cause noise in the pump (control valve or power piston)?
If the Power Piston in the gear box is worn or stuck or broken, what would that do to the pump?
I have for some time had a little seepage from the cap on the reservoir. When the cap is off, the fluid rises up and almost out of the reservoir when the motor is running. Is this normal? There are no bubbles or foam when this happens.
If I over steer in either direction, the rise in the reservoir will stop.
When I drive, with the old and new pump, there is no loss of steering.
If the seals in the gear box are worn or leaking, I should have a loss of steering, right?
What about if the control valve for the gear box. If its stuck worn or leaking, should I have hard steering, right?
Power Steering bleeding test question.
The FSM says to check that he fluid in reservoir is not FOAMY or Cloudy and DOES NOT RISE OVER MAXIMUM when engine is stopped.
1) Should I be able to check the reservoir level with motor running with the steering wheel at rest and wheels facing forward?
2) When doing the Bleed test, the pic in the FSM show RPM's at 1000. You measure the fluid level. Is this with the wheel turn to LOCK (turned all the way) or is it when the wheels are forward and not turning the wheel?
The only way I could measure the level of the reservoir is if the steering wheel is turned all the way.
I drove with the old pump making noise for a couple weeks with no affect of steering. It all started after I rebuilt the old pump.
Should this happen?
