I have noticed a problem with my 97 FZJ80 power steering the last two times out wheeling. The first time I was going up an obstacle called the elevator shaft. It is basically I long, steep, uneventfull hill climb. I was locked front/rear and in 4lo. The steering was squeeling a little bit and it went out on me until I got to the top and unlocked the front. The rest of the time it was fine. Fluid looked good and the level was fine. I decided to flush the fluid using a tranny flushing machine that we have at work. I now had fresh tranny fluid running through it. I went wheeling again and after going over another steep incline, I lost power steering again. I was locked up front and rear with this obstacle as well. The problem didn't go away until I unlocked the front. The rest of the trip went fine.
I take it that this can't be normal behavior when everything is all locked-up? I know that it isn't binding that I am feeling. Is this adding too much stress on my steering? Does the steering normally go out at steep angles, or am I just in need of a new pump?
