Power Steering problems
MDarius
I break stuff.
Bountiful, UT
There are a lot of PS threads out there. I now know how to replace my fluid and replace my pump. Here's my sitaution: My pump has been groaning for a few months now when it's been running for a while. It looks like it is leaking out the back. It hasn't been real bad though and I've been putting off doing the replacement. We were planning on going camping this weekend, but the leak is bad enough now that it shows on the driveway. It didn't start groaning until I took it to the dealer and had some work done in the same area.
My question is, what is the life cycle of the pump? Can I do something to help it limp along through a weekend of camping until the timing is better for a repair, like during the week, or is it risky to drive it?
The fluid is dirty and needs to be changed. I know in older cars with oil leaks you can change the oil to keep the viscosity up and reduce the leaks. Would this work to limp through a weekend?
I WILL fix it, I just wanted to leave first thing in the morning. Car repairs will kill my day off and my family plans.
Thanks!
Bump. Has anyone had a PS pump go out? What is the life cycle like? Something like:
1. Groaning
2. Leaking
3. Complete failure and shredding of parts
or is it more like
1. Groaning
2. Leaking
3. Leaking for the next 20,000 miles
4. Failure, but you can drive it for another 100 miles to limp home
Any ideas?
If it's not leaking out quickly, just top it off now and then until you can fix it. If you run dry after 20 miles or so, you should probably replace it or risk damaging it....
If it's not leaking badly, then I would do a flush and maybe refill it with synthetic ATF. That may quiet it down for a while.
You can run the PS for a long time with a leak. I think I've had my PS leak going for over 20K miles. It is slowly getting worse, but I just top it off and call it a day. I've got two extra pumps as well as a OEM rebuild kit. I'll probably do it at some point, but right now, it does not warrant it.
I just keep a quart of some ATF sitting in front of the battery and top it off as needed.
Good luck.
-onur
The fluid is dirty and needs to be changed...
Thanks!
Bad, old fluid alone can/will cause groaning, I would flush it. If that fixes the groan, then take it off, clean and reseal at a later date. For a quick flush test, use standard ATF or light hydraulic oil. I have had much better results from light hydraulic oil in Toyotas, smoother and no groaning, run Mobil DTE light in mine.
Thanks!
That's exactly what I needed to know. I'll flush it, fill it with good fluid, and fix it in a couple of months. Thanks for your responses.
Follow up: Flushed the fluid and replaced with ATF. I figure I'll need to replace the PS pump soon. With that in mind I picked up some ATF stop leak and dumped just under half a bottle of that in as well. Groaning is gone, steering is easy, and after a full day (120 miles) of driving on trails and freeway there was no leak. I figure if the stop leak does any damage I was going to replace the pump anyways. If it doesn't I may get to live with the pump I have much longer. In the meantime, I'll add a few dollars each month to the repair fund and be ready when it goes out.
Thanks again!
mine is groaning and leaking slowly. It's been over a year doing this. You can try to add a tablespoon or so of Downey fabric softner to it, that will sometimes quiet it down.
My thoughts on the pump at this point is as long as my wheels turn, i will not touch it.
