Power steering lockup?
Placerville, CA
So my son is driving the cruiser, calls me up and says the steering locked up turning right. I control my sudden rage and ask if everyone is alright. He says yes, and says he has witness'. Go and load it up on the trailer and bring it home. Its has saginaw power steering, V8, blah, blah, blah..
Seems to fine at home. I check everything. Nothing loose, binding, fluid full.
I was driving it yesterday and it was fine for an hour or so. Then it happened, on a stretch of a nasty country road. Locked up going right. I stopped, backed up and it worked fine to get home.
Any thoughts. Steering column, dont think so. Maybe the box itself?.Thanks in advance.
immediate thought is a broken birfield. when broken the shattered pieces float around in there and get locked in the knuckle preventing it from turning. It can work itself loose (you backed up) but it could (probably will) happen again. After being broken, it doesn't matter if you are in 4WD, locked or unlocked hubs etc... the damage is done and the problem remains. This is of course a VERY DANGEROUS SITUATION!
do you have locking hubs? were they locked when you were driving it?
is it possible your son was playing in 4WD before the problem happened? ...and the birfield broke? (something that might be hard to get a truthfull answer for :D)
you could try lockeing the hub and putting it in 4WD in a SAFE area (driveway?) and see if you get a bunch of cluinking/ grinding noise from one of the knuckles. if so it's definitely a birf
It's possible it's the box. We'll have to hear from some of the guru's if this can happen. I've never heard of it. (but that's by no means conclusive :D)
Welcome.
Been there. 35+ MPH too…
What kind of coupler do you have between the steering shaft and the steering gear input shaft?
I have a spud shaft on the Red truck and a small stone...one the size of a pencil eraser found its way into that open area behind the steering gear and eventually into the area where the coupler rotates. The small stone was enough to lock my steering up and make me end up in someone’s front yard.
I have checked that area every time before I operate the truck.
I have seen Saginaw steering gears go bad and act that way as well.
their was a thead early this week where it was the box,atleast no one was hurt
Thanks for the replys. Dont think its a birf, have got the longfields (inner and outer) in. Will check anyway, was going to replace/repack inner and outer front wheel bearings anyway. Got locking hubs, they are unlocked. I did check the shaft coming from the firewall to the steering box.. Its tight. I also thought about something getting into the lower joint on the shaft and locking it up. Couldnt find a thing. Will do some more touchy-feelie stuff. The one thing I did notice when it locked the steering wheel seemed to "bounce" back and forth. And after I pulled my shorts out of my ass, I just went home and had a couple of adult beverages.
Thanks and will keep everyone informed.
Was also thinkin about putting all 4 tires in the air and running in 4wd, turning back and forth. Will give it a shot. Again, thanks for the advice.
Finally got it figured out. Put the front end up in the air. Cycled the steering for about 20 minutes. No lock-up. Put it back down on the ground. Cycled for about 10 minutes. No lock-up. Raised passenger tire to bump stop. Cycled for about 5 minutes. No lock-up. Same for the other side.
Having looked thru that hole in the frame where you can tighten the steering shaft and not seen anything, didnt think of looking again. But I did, and to my amazment, there was a rock. Dont know where it from, cause it was not there before, but there it was. Got it out and everything is fine. Might have been lodged up top, I dont know. Anyway, will be putting a plate over that hole. But checking everytime before I do that. Twilight Zone! So just be aware that it can happen.
