I have been experiencing an occasional belt squeal when turning the wheel and also every now and then at higher rpms (2800+) in my 92 3FE, 221k miles. I get more and more squealing as the tire pressures get lower (assuming the pump has to work harder) and at 20lbs I get some binding on the pavement.
When I went to check the ps fluid I found it was a little low (maybe and ounce or two) so I topped off. But what caught my attention was the pulley had fore and aft play in it. Up and down and side to side it is tight, but I can pull the pulley and shaft out maybe an 1/8th of an inch or so. Would that mean I need a new pump, or replacement of the shaft or is that an acceptable tolerance?
The belt itself appears to be a tad loose, but I'm not sure where the adjustment bolt is. The ps pump appears to have a slide on it, but the bolt looks to be all the way to the top already.
