Power Steering Issue - need advice
Where the glaciers stopped.
i searched and did not see what i was looking for. roast me if need be...
as soon as i pulled into my drive from day long wheeling trip I noticed some extra 'whine' from my steering.
got out of the truck and saw fluid coming off where the steering arm (sector shaft) connects to the pitman arm. leaked out a bunch of fluid (at least a quart) and now the steering is more labored and loud.
i have not driven it since, except to move out of the way in my driveway, and have not added more fluid becasue i assume it is just going to come streaming out based on the rate at which it was leaking when i stopped.
any suggestions as to how to trouble shoot this? thanks in advance for your time and expertise.
Lower seal shot, time for rebuild. Choices are:
(a) Use yours as a core for a "rebuilt" supplier
(b) Look into other choices that may not cost too much more and additionally offer Dual Stage Valving.
No matter what you do, try to stay with same hoses (SAE or Metric, i.e. 1980-older or 1981-newer), and stay with same input shaft spline and diameter so that you don't have to change lower u-joint.
Don't run the engine without P/S fluid you will destroy your pump.
They make rebuild kits for the power steering gear box, they're super cheap. I rebuilt my 4-runners box about 2 years ago and not a drop from it since. It was different, and took some fanagling to get all the balls back in the box, if your not confident with your wrenching skills, I'd just go for a rebuilt one.
Pull it off and reseal it. OEM Toyota was like $120 and the Gates kit (P/N 348437) I picked up can be had online was $29+ shipping. It's not a difficult job especially if you can get by without removing the balls.
My plan would be to first confirm for sure where it's leaking. If it's the sector shaft seal, it's relatively easy to replace, the hardest part is getting the pitman arm off.
How do you know if the box is still good
My PS box is leaking and how do I know if it's the seals/gaskets and not larger issue inside? At 182,xxx, just do the rebuild and fahgedaboutit??
