Power Steering Gear Repair
North Front Range, CO
I dinged up several teeth on the power steering pump gear. I filed/Dermeled down the bad spots and there is no more noise.
Do I need to spend the $100+ gear or can I just use the repaired gear?
The damage is already done. I drove for a couple weeks with the damaged gear meshing with the drive gear.
What will be the problem with several teeth filed to remove the bur?
Will a few .01 or .001 of an inch make any long term gear meshing difference. And how many more miles will the my 80 go anyways???
A few weeks ago I dinged one of the teeth on my psp gear and asked about it here on Mud. It was recommended I just file it down and put it in, which is what I did. But I only had one small or two small dings on mine. Yours might be worse.
After a 1000+ mi there is still some noise. It must be the tight tolerances that Toyota had back then as the gear with 321,000 mi on it had not one bit of wear on it. I assume that the noise is the gears not meshing 100%. OR the nicks in the PS gear marred up the drive gear too and the two them together are making noise. If I had a job I would buy a new gear but it will just have to wait till times get better.
