Power Steering Fluid Problem
Vermont
I replaced my power steering pump two days ago with a used OEM pump. It was loud as hell as there was air in the system. I've bled the pump and got the fluid clean w/o foam or bubbles, its quiet.
My problem is that an hour or so after I've bled the pump the moan comes back, the fluid gets foamy and I find fluid leaking from under the cap. Sounds like air is getting in somewhere, could be the cap? Before I replaced the pump I checked all lines for leaks and found none so I don't think air is getting in from any of the lines.
Seems like the biggest culprit is the large O ring sealing the pump to the block. It's easily dislodged while you're putting the pump up against the block. Not what you wanted to hear, but there it is. Did you get a new Toyota O ring for the install?
DougM
i reused the old o-ring so thats that. i'll get a new one and put it on, see what happens. def air getting in, i bled for an hour this evening and couldn't get it to clear. the whole area under the pump is such a bloody mess now. i just cleaned that s***e couple days ago.
I'm having same problem in my rig- did the O-Ring solve your air leak?
Thanks!
DougM
That O ring (the ~3" diameter orange one) seals the pump to the block to prevent engine oil from leaking out. It has no effect on the sealing/leaking of the pump, so I don't think it would be the cause of air in the PS system.
There is a little O ring that seals the intake pipe to the pump which has be known to let air into the pump. I'm not sure if it's available separately from the Toyota rebuild kit, but it shouldn't be too hard to find a replacement at a parts store. The rebuild kit is pretty cheap though, and it is an easy process if you're so inclined. I rebuilt a used OEM pump last year and it's been running fine since then.
can someone post the FSM diagram of the p/s system?
edit:
i'm not too keen on having to re-build a pump i just purchased. i admit its a used pump but still...
that did it, so far so good.
