Decided to flush some of my power steering fluid to Mobil 1 DTE 24 fluid today. Also got into some diagnosis for my code 71.
Power steering fluid was nasty looking. Was only able to flush a small amount at a time by sucking it out of the reservoir and replacing, but the final fluid was lighter color after 4 changes. I attached a pic of the nasty fluid.
Also pulled all the vacuum hoses between egr modulator, valve and throttle body then pulled and cleaned the egr temperature sensor. The vacuum hose from the bottom of the egr modulator to the egr valve was pretty much clogged. I knocked a lot of junk out of it. The temp sensor was really black too, so I cleaned that up. Tested the valve while sucking on it at idle and it almost stalled, so thats good. Hopefully the CEL will go off here and I can retire my code 71.
Pics...
Pics...
