Power Problem with 3FE
Hello
After a long time of being stopped I finally got my FJ80 running. However it is not running too good. My Landcruiser is lacking power, big time! :mad:
I think the problem lies in the throttle linkages but I'm not sure (transmission kick-down). Whenever I press the accelerator, the harder I push on it the less power there is. The RPM will stop at about 1000 RPM and it's like shifting a manual car into high gear while your going slow. It will not speed up. If I press very lightly on the gas pedal the Landcruiser will speed up but it won't go too fast.
I've adjusted the transmission kick-down cable with mixed results. The manual says to adjust it to 0mm - 0.50 mm. Someone in another post mentioned adjusted the throttle cable instead. Also the engine get very hot! The temperature gauge stops at the normal middle level but the exhaust pipes on the driver's side get red hot. The entire area near the exhaust gets very hot. The fender is burning hot to the touch but yet the temperature gauge reads okay. This is only with a spin around the block. Less than a mile. I've done all the basic tune-up.
I'm stumped. I know the 3FE is an extremely good engine but so far I haven't been able to see that. I don't want to ruin my engine neither. :crybaby:
I know I wrote a lot but I'm just trying to get the best help.
Thank you very much! :p:p
Just curious...You said after a long time being stopped, why was the rig stopped? Also what maintenance have you done to the rig prior to the current symptoms?
I would def say a clogged cat, see how much pressure is coming out of the exust and if it is so hot that it could burn your hand try disconecting it and take it for a drive
Hello
I know it's been a long time since the original post. I finally got around to check out my FJ80. It wasn't the cats. After some troubleshooting and the help from another fellow Landcruiser owner, I discovered the problem was the ignition timing. After some difficulty getting it right I finally fixed it. I never knew that a 3FE had so much power!
Thanks for all the help!
