Power outlet problem (front)
Kazakhstan
Have a problem with front power outlet on my '08 LC. Same time cigarette lighter socket works well same as rear 110v outlet. I have checked related fuse units all are good not burned. Looked behind of panel and checked wire/connector it has no power same time upper works. Seems as there loss somewhere. May be someone has idea what could be a cause ?
Thanks in advance.
Thanks in advance.
Where is this front power outlet? In my LX there is a rear power outlet near the rear hatch opening, but I wasn't aware there is an outlet in the front, at least in the LX.
It is under ciggaret lighter socket, basically it looks the same.
Are you sure you didn’t deactivate your 110 AC outlet via the on/off button?
On my 08, it’s in the button cluster to the left of the steering wheel, and is easy to accidentally toggle off by accident due to the invisible spot they crammed those buttons...
Sure I tried to use it in different combinations, switched on and off and different "position" of ignition button. BTW, this outlet works the same way as rear 110v socket ? Just when button on the panel and ignition activated?
Stupid, but in my case the root of cause was fuse. Don't know how but i confused position of correct one. After replacement everything works fine. But anyway i did direct connection to ACC to have chance charge devices and fridge (which i prefer to have on rear seat) without switching ON start button.
