Power inverter install
Prescott Valley, AZ
I finally pulled the trigger and put a 110 volt power inverter in my rolled over wreck. I checked out a lot of units, thinking about how much power I really needed. In the end, I went for the big one! It's only expensive one time!It has a 2,000 watt capacity, 4,000 watt spike. It has three cooling fans in it to draw off the heat, two for intake and one for exhaust. I can run my portable table saw and my 10" chop saw at the same time, as long as the engine is running.I mounted it on the right side of my drawer system in the cargo area. It takes up the entire space behind the right fenderwell. I ducted the cooling fans to take air from one compartment and exhaust in another. Wiring this thing was a nightmare. I had to run two 4 AWG cables from the right rear to the battery in the left front. That was just to supply power to it. I once thought that routing speaker wires was a pain in my a$$. This trumps stereo wiring several times over.I ran two heavy cables through the body to the battery. The cable that I used is double-insulated, but I treated it like a bare wire. From end to end, it is free-floating. It is routed and mounted on insulating supports. It is not allowed to touch any metal in any place. I placed a third layer of insulation at every mounting point. It is bolted down every 6 inches. I soldered every fitting with a torch, and insulated every mounting point.Laying the cables through the body took me two full days. It was a chore. I had much of the interior removed to fit the cables. Now I have a solid source of 12v power in the back of the truck, as well as 110v.
Next in your shoping list: a big alternator !!!!!!
Pics may be tough. Space for taking them is limited and some of the routing is thru my drawers, which are unique.
The inverter is Harbor Freight item #95596-5YBA. The last four are a sale price designation that is good until 6-1-08. The sale price is 149.99. Phone # is 800-423-2567.
This unit is much too big to be ignition-controled, so I can't use it for phones or lap-tops. I have to open the back and switch it on when needed. It is mainly for my work, not for off-road, but it will run a compressor, so I can have a bigger one when I need it. It will easily run a blender or small microwave if I want to.
For cables, the unit calls for 1AWG cable to the positive side of the battery. But the #1, with insulating cable mounts was over an inch thick under carpet. Two strands of #4 ga lays flatter and carries more current than a single #1 cable. It also costs a hair over 1/2 as much.
From the inverter in the RR, I ran the cables foreward to just behind the mid-seats, at the front of the cargo area. I then ran them across the floor to the LR fenderwell, and then along the floor above the rocker channel. I punched them thru the floor just ahead of the base of the B pillar and under the truck. Inboard of the rocker are several threaded bolt holes and a stud welded into the body. I fabed mounts to fit these. I loosened the bolts holding the front fender skirt to the firewall and fed the cables thru the gap. I covered the cables with 1/2" oil hose where they pass thru, and tightened the skirt back to the firewall, trapping the cables. From there, I brought them up to just below where the left fender mounts and then foreward to the battery.
Bear in mind that this is some HEAVY power here. I.E. the positive battery terminal is extended 19 feet to the rear of the truck. The cables themselves are double-insulated, yet I treated every inch if cable as if it was bare wire! No part of the cables will be allowed to touch metal! They are well-insulated over the full length. In most places, the cables are mounted every 6 inches in an insulated mount that keeps them well away from the body. Where they pass thru a panel, they are fed thru a length of heavy hose that is glued or clamped in place. Every inch of cable should be at least 1/4" away from any other metal part. Do not mess around with this stuff! Spend the time to do it right.
It took me a day and a half to route the cables and fab the mounts for them. That was after the inverter was fitted. It is worth it!
Sometimes I am not so sure about my green paint, but it is a lot better than charred black on the side of the trail! When installing an inverter, you are messing with some serious electrical power and possible disaster. Allow time and cash to do it right.
As my biz is slow this time of year, I set aside a week for the install job. I was lucky to get it done in 3 days. I used to do this for a living. I was able to use the extra time to help take my daughter's school on a field trip.
Most of us have not done much of this kind of work. Think of running speaker wire thru the body, but it is several times as heavy a wire, and if it shorts out, you need a new truck! It is that serious!
Bryan: I installed on my cruiser a front a rear fast coupling high amp plug from Warn to power a jumper set of cables and a removable rear hitch mounted 8000 lbs winch and this setup includes a heavy duty continuous use solenoid of about 400 amp load capacity controlled by an indash iluminated switch.
I guess that this should be a safe way to hook the inverter and in case that something goes wrong, you just could turn off the solenoid from the dash. Conversely the main reason I did it, was to avoid any dangerous situation when some loony could do a short between the negative and positive pins of the plug when I were away of my cruiser because the plugs are not concealed. By the way, been able to jump start another vehicle from the rear of my cruiser is a big plus but unfortunately since my solenoid works only with my ignition switch on, if I am out of juice nobody can jump start me, something quite uncommon since I carry 3 batteries.
