The tricky part is getting the coax of the replacement antenna assembly back through the 90 degree hole at the back of the fender and into behind the dash. When you pull the old unit, be certain you attach a fish line to the coax plug inside the cab so that you pull it out it gives you a way to get the coax from the replacement back inside.
That said, it's not easy. You will use words you're Mom won't approve of.
Have you checked the fuses, connectors, and wiring on the old? Just so you're certain why it's dead
I'm not sure if the '94 has a dash mounted antenna switch, the '96 does. On earlier models turning the radio ON/OFF caused the antenna to extend and retract. That feature "might" make a big difference in your intended swap. I don't know if it would or not, just pointing out that difference.
Rockydog1, does the antenna motor it self work when the button is activated? If the motor is working then the nylon cable inside the spool is probably broken and can be replaced.
Well I bought an antenna off a 96 fzj80 for $80 and will try to install it. As I was looking the old antenna over tonight I noticed ther is a small fuse box spliced into the wires that run to the antenna. The box is labeled diagnostics and it has about 6 empty slots. This box is never mentioned in the OMM. Huh? I assume it is for diagnostics and wouldn't hold a fuse for the antenna
