So when I purchased my 80, the antenna was already broken off. I've finally gotten around to replacing the antenna mast. The mast can now fully extend and retract.
The problem is, it seems like the gears inside are slipping. It won't go up smoothly (extend, stop, extend, stop, extend.. etc.) even though the motor is running consistently. It also won't stop retracting once it is all the way down. The motor keeps trying to retract until it times out (15 sec or so). You can hear a bit of clicking while trying to retract. I've opened it up the antenna assembly to ensure no bits are stuck inside.
I believe the small plastic gear in the attached picture may be worn (picture is from an LS400, but probably similar). What do you guys think? Is there a replacement plastic gear available without trying to scrounge in a junk yard or buying the whole antenna assembly?
Did a search, but only found things on replacing just the mast.
