Power antenna motor, help, location ect
Gig Harbor WA
So my antenna is busted(friends kid was playing with is), there is no cable left for me to get to, the antenna just pulls out(if I undo the nut), so I assume I cant just replace the mast......because the cable is stuck down in the motor, it won't run up so I cant grab it
Is this correct? am I looking at a new motor as the only cure?
and where the heck do you get to the motor at? I looked in the engine bay.....can't see a way to get to it, is it maybe behind the PS kick panel? anyone ever pull one of these? the FSM doesn't mention replacing the motor......no help there
never mind, I used that handy search feature and found some great posts on the subject, happy just need a new mast and take the old motor apart
might be a PITA but alot easier than where the motor is on a 80 series
I had to replace it, not very hard to do but took me about an hour. I made sure to have a few of the plastic plugs that hold the wheelwell liner handy incase my fat fingers decided to destroy them during the process. I did! Tight fit, take your time.
Assuming these are the same as the rest of the Toyota family.
If it is just the mast, or the white plastic teeth - they are available on ebay and very easy to install. Toyota plastic teeth break all the time and freeze too - I have replaced 3 now, one for my 95 4Runner, and 2 on Lexus 400's. Search ebay and you save tons over a new motor. The install is just to turn off the radio and insert the teeth at the same time and it pulls it into place. I just searched and it is $41 + $6 shipping. See Bridgewood Motorsports.
If I read the list right. The plastic line is in the motor housing. If that is the case pull the motor, open the housing and remove the extra line. Hint remember which direction the teeth face. There is an article on the site which will walk you thru it.
Button it back up then (with the help of second person) turn on the radio. Feed the line, then turn it off the radio and the line should retract. Secure antenna base. See easy.;)
Sorry, guys, prolly a stupid question:
My antenna shaft is broken, but when the radio is turned on, the white cable still comes up....and just lays over because, of course, the broken shaft will not extend. Dealer told me I needed a new motor and quoted me a pretty significant price but from reading this thread, it sounds like I can just get a new shaft, get to the motor and feed the new toothed cable into it....right?
Thanks..............
kitkraft, you are lucky. It
It sounds like the white toothed strip is still intact. You will be able to remove the broken mast and its still-functional plastic strip, without having to touch the motor under the fender. Much simpler for you to DIY than the guys who have to take apart the motor to retrieve the broken plastic strip.
Dont' be discouraged by this long post......It's a one-sip-of-beer job.
Find a friend (not necessary, but helpful. It's DIY if you roll down the passenger window and have long arms and are quick footed.)
Unscrew the slotted collar nut that holds down the base of the antenna mast at your right front fender. You can turn it with a large pliers if you don't have other tools. Carefull not to scratch the chrome on the nut, or the paint on your fender. You do not remove the rubber boot. Just leave it there.
Turn on radio. Antenna and toothed strip comes up and will stop at some poinit. My 2000 TLC has an up/down antenna button on the dash. Give the up button an extra poke to be sure it's all the way up. Notice which direction the teeth are facing. The Factory Service Manual says they should face rearward. Do NOT turn off the radio.
Now pull straight up on the plastic toothed strip to pop it out of the motor. A gentle 2-10lbs of upward force should do it. The tip of an intact strip will still have a bevelled cut at the end to make it slightly pointy. (The end of a broken strip with be more obviously cracked straight across; which would indicate there might be a need to dive into the motor. ) Throw away the old antenna mast/strip.
(I don't remember if the rubber gromet boot is permanently mounted to the antenna mast or not. If it comes out with the old mast, and if you can see a new boot on the new mast, then it should be obvious as to whether you need to reuse the old rubber boot.)
Insert the end of the new white plastic toothed strip, with teeth facing rearward. Feed the strip down into the hole until you feel it go into the motor. When the first tooth hits the motor, push down a little to make sure it is engaged with the gear that will wind it in when you turn off the radio. Make sure the mast is in its shortest position and the entire plastic strip is exposed, ready to get drawn into the motor.
Now, tell your helper to turn OFF the radio. The motor will start winding in the toothed strip while you carefully keep feeding it into the hole. Your challenge is to feed it in with the teeth pointed the same way the whole time, without twisting. It goes slowly enough that you will be able to keep up. When it gets near the end, you can guide the antenna mast down into the hole. When the motor stops winding, don't worry if there's still some plastic toothed strip showing. Insert the mast into the hole (extend the antenna with your hand a little bit to take up the slack of the plastic strip that's still showing).
Put the collar nut back on to secure the mast onto the base in the fender, and tighten down (doesn't need too much torque).
Now turn the radio back ON. The antenna will come up and stop.
Now turn the radio OFF. The antenna should go ALL THE WAY down this time, taking up the extra slack.
Finish your beer.
No problem. In your excitement to get home, don't forget
to buy a replacement mast at the dealer ($45ish?) or get it from an online supplier if you are willing to wait.
Also forgot to mention that I think the collar nut is made of chromed plastic.
If you use a set of pliers to turn it, don't squeeze too hard. It could crack.
Make sure your old mast has all its plastic strip attached when you pull it out or you'll be tearing into it again before long if you leave part of it in the motor. The PO of my 100 just replaced the mast without removing the piece that broke off because I pulled two pieces out when I replaced it again after it broke--for a while it would sometimes go all the way down, sometimes not. Depending on how it coiled up in there, it may not have had room. Then it broke. Still not a hard job, just a little dirty and greasy. Less than an hour. Spare plastic plugs are a good call. I only broke one.
guys, got my antenna mast($35 in stock at my dealer) and 10 of the clips($4)
no hurry to pull it all apart, antenna is still there and will wait untill I bust it off all the way
and yes, mine is busted off and stuck in the motor
Odd the manaul says the teeth face to the rear but read here they face the front, which is it? done the mast replacememt many times in my 80 and on co-workers 4runners, thats easy
Kitkraft: No problem. Glad I could help. But check teeth direction...
Landpimp:
You are right. The FSM says teeth face to the rear (not front) of the vehicle. I was writing from memory. I'll edit my post. Good price on the mast.
Kitkraft: I suggest you check on the teeth direction of your install. You might want to pull it out and feed it back in the right way. Sorry for the misdirect.
Landpimp:
Uh-oh! But, I swear the old one came out teeth front....then again, it was broke!...lol....
Thanks again.......
FYI anyone doing this job should use the OEM Toyota part! I ordered one off of e-bay off a shop that sells just antenna masts. Broke 3 months later on the LC, and never worked properly on my 93 SC300.
OEM is the only way to go here.
I read this thread on Monday and my antenna broke today. Excellent timing. Half of the antenna is broken and still in the motor. I know I need to remove the motor to get the remaining antenna out. The motor under the fender is wrapped in a plastic bag. How have others dealt with the removing the motor from within the plastic bag? I also want to confirm that when inserting the antenna, the teeth on the plastic cord needs to be facing backward.Thanks guys....
Antenna Replacement
I did mine today with some tips from old posts. Had to remove the motor to get at the lost plastic toothed strap. I took a few pics during the process and could do a fairly good how-to write up if there's any interest.
I replaced a broken mast years ago in a Cressida and it was a 5 min. job. When the toothed plastic is in the motor it becomes a fairly involved repair job. Mine broke at 105k miles. At less than $40 for the mast from CDan I will do the mast again as preventative maint. at 190k miles.
It gave me a chance to clean out inside the lower front fender area between the wheel well and door that always seems to collect sand, dirt, etc., and is hard to get at.
-Mark
