Power Antenna Help
97 LX450-My power antenna cable broke so I opened up the housing and removed the old one, and fed in a new mast. The new one only comes up about an 4 inches and stops. I removed it and fed it in several times and the same thing happens. I pulled the antenna out and shut off-turned on the radio to listen to the motor. When I turn the radio on the motor runs for about 2 seconds and stops ( thus the 4 inches of antenna), but when I turn the radio off I hear the motor running (as if it's lowering the antenna) for about 20 seconds before it shuts off.
Is there any type of adjustment or set up to get the antenna fed in properly, The new one didn't come with any instructions.
Thanks for the help.
Ed
Ed,
Just starting with the basics here but when you are feeding in the new mast are you using the antenna controls to pull the antenna down in? I assume you know that you can set extension height of the antenna with the button correct?
Just making sure your problem isn't something simple like having the height set real low with the button :)
When I replaced my antenna I had the :princess: working the button while I fed the mast cable in, then secured the mast, ran the antenna full up and full down several times, set the extension height, and called it good.
This site may help...http://www.spokanister.net/vehicles_antenna.htm
Glad I was able to help! Usually it is the opposite with my suggestions :D
