Okie, FYI, the early 70s model radiator shrouds were actually yellow zinc coated, which quickly oxidized to a greyish color. I believe on later cruisers they were painted black. I can't remember if you're trying to do a correct restoration, or not. I've done a lot of engine sheet metal including skid plates in semi-gloss black, which is close to the original color. However, I think the gloss black makes things stand out really well, so I've been doing a lot of my recent work in that color. Make sure you ask about the shops prep work. They should bake it at 400 degrees to cook off any impurities, and make the bead blasting of old paint easy, before shooting the color, and putting it back in the oven to set the powdercoat. I've had powdercoat fail, which isn't that big of a deal for engine sheet metal, but could be a problem if you're doing a frame, or other labor intensive part of the vehicle. Most reputable shops periodically test their work to see if it holds up to stress.
