Possible PHH fix?
New Mexico
I've been pondering, since I just replaced my pesky heater hose, could you put some clamps along the length of the hose, not tight, but snug, to prevent the OEM hose from swelling? I'm thinking this would keep it from loosing structural strength, and having the metal band along with the overlapping clamp tail, would help dissipate some of the heat as well.
I'm only thinking this because nobody in town had silicon or gates hose, and I had to replace it. The only thing I had was the OEM hose leftover from my overall hose replacement kit. I know, proper planning...
Anyway, for those of us using the OEM hose, could this help it last a bit longer than its usual life?
-Eddie
That sounds like a great idea, and it will absolutely add structural integrity to the walls of the hose.
Im curious I havent done my due dilgience on the PHH problem, do they fail in the center oh the hose? or at the ends?
Don't you think it might be easier to replace it again in say, oh, 100,000 miles? How long did your first one last?
-Spike
-Spike
Exactly. The next one will last just as long and will many, many times easier to change. In 100,000 miles change it out with a silicone one.
The clamps along the length doesn't strike me as a good idea at all.
My truck is at 136k, and this is at least the second time it's been changed.
Thinking about how this problem occurs, it seems that lots of heat rather than massive pressure is responsible for the walls of the hose breaking down and weakening, causing it to stretch and further making the rubber thinner and weaker.
If you were to add strength to the walls, before they break down and stretch, you would add life to the hose. Dissipating the heat also is a preventative measure.
It's kind of like the hose develops an aneurysm, by the walls becoming weak. Just thought it would be a preventative solution for someone's hose who isn't in a position to change the thing out.
-Eddie
-Eddie
I think you've answered your own question and don't realize it. It's the heat that kills. Use the silicone hose, it takes the high temps. The bulging is a symptom of the problem, not the cause.
Plus isn't it possible adding metal bands isn't going to dispate heat, but rather transfer more to it. The OEM rubber is already rated to withstand standard operating water temps. It's the surrounding block heat added to it that is what I think is causing the strain.
I think the hose is there because that section vibrates. Otherwise Mr. T would have put a direct coupler on the pipe and been done with it.
Putting a hose clamp on it in the center could lead to that clamp biting the hose or interfeering with it's ability to flex.
Consider this... if it can't flex, the movements and strain would be pushed to the nipple on the block. Which would you rather change? The PHH or where it connects to the block?
It would still flex as the individual clamps aren't tied to each other so is kinda like a bendy-straw or a poor-man's braided steel line.
Can't see that it would hurt, and like Eddie says, adds some structure to the outer jacket of the hose and keeps it from bulging. Probably not much of a heatsink but a nice thought.
Not a bad idea if you really can't get hold of the silicone stuff...
