Possible New Owner
Charlotte, NC
Well, after months and months of searching and losing out on two local GX's I think I finally found one. Completing paperwork now then plan on having it shipped from Texas to NC but wanted a quick double check from the members to see if anything from the service history jumps out or screams red flag:
Overview:
2006 w/132k miles
5 Owner
Clean CarFax/Autocheck
Texas Vehicle its whole life
Appears to have been regularly serviced according to the CarFax (Dealer maintained thru owner 4)
Dash replaced at 56k
Water Pump replaced at 130k (will still need to get timing belt done)
Lexus Service History via MyLexus:
81558 MILES
DATE:
05/10/2013
REPAIR# 0496830
REPORTED BY: Westside Lexus
SERVICE: NON WARRANTABLE OPERATION CODE
DESCRIPTION: NON WARRANTABLE OPERATION CODE ~|~INSTALL MARK LEVINS AMP WARRANTY JOB ~|~AMP IS WORKING NORMALLY AT THIS TIME ~|~NO WORK DONE
SERVICE: WORLD CLASS INSPT'S
DESCRIPTION: WORLD CLASS INSPT'S ~|~WORLD CLASS INSPECTION ~|~PLEASE FIND AND REVIEW ATTACHED VEHICLE INSPECTION REPORT ~|~ATTACHED INSPECTION REPORT CONTAINS IMPORTANT INFORMATION ABOUT YOUR VEHICLE.
74483 MILES
DATE:
09/19/2012
REPAIR# 0546814
REPORTED BY: Sterling McCall Lexus
SERVICE: ASR
DESCRIPTION: ASR ~|~VEHICLE INSPECTION REPORT ~|~CUSTOMER REQUESTS VEHICLE INSPECTION REPORT. ~|~74483 CUSTOMER REQUESTS VEHICLE INSPECTION REPORT. PERFORMED VEHICLE INSPECTION REPORT.
SERVICE: CAR
DESCRIPTION: CAR ~|~CUSTOMER REQUESTED A LOANER ~|~CUSTOMER REQUESTS A LOANER CAR. ~|~74483 CUSTOMER REQUESTS A LOANER CAR. CUSTOMER REQUESTED A LOANER CAR.
SERVICE: IGN SWITCH LCK CYL & KEY SET
DESCRIPTION: IGN SWITCH LCK CYL & KEY SET ~|~CUSTOMER STATES: NEED DUPLICATE MASTER KEY AND VALET KEY ~|~THE IGNITION SWITCH LOCK CYLINDER WAS BINDING AND WILL NOT ACCEPT NEW SET OF KEYS. ~|~74483 THE IGNITION SWITCH LOCK CYLINDER WAS BINDING AND WI...
SERVICE: MISCELLANEOUS ELECTRICAL SYSTEM - REPAIR
DESCRIPTION: MISCELLANEOUS ELECTRICAL SYSTEM - REPAIR ~|~CUSTOMER STATES RADIO CUT OUT AT TIMES(WHEN THIS HAPPENS THE SOUND WILL CUT OUT BUT THE RADIOS LIGHTS ARE ON) ~|~DEFECTIVE MARK LEVINSON AMPLIFIER CAUSING NO AUDIO. ~|~74483 DEFECTIVE MARK LEVINSO... MISCELLANEOUS ELECTRICAL SYSTEM - REPAIR ~|~PROGRAM NEW KEYS ~|~CUSTOMER REQUESTS TO PROGRAM ONE NEW MASTER AND ONE NEW VALET KEYS. ~|~74483 CUSTOMER REQUESTS TO PROGRAM ONE NEW MASTER AND ONE NEW VALET KEYS. 50 PROGRAMMED BOTH NEW MASTER A...
SERVICE: PERFORM TEXAS STATE INSPECTION 96 AND UP
DESCRIPTION: PERFORM TEXAS STATE INSPECTION 96 AND UP ~|~PERFORM TEXAS STATE INSPECTION 96 AND UP ~|~CUSTOMER REQUESTS 1 YEAR OBD STATE INSPECTION. ~|~74483 CUSTOMER REQUESTS 1 YEAR OBD STATE INSPECTION. 50 PERFORMED 1 YEAR OBD STATE INSPECTION. VEHICLE...
SERVICE: STEREO COMPONENT AMP ASSY
DESCRIPTION: STEREO COMPONENT AMP ASSY ~|~PARTS WARRANTY-RADIO CUT OUT AT TIMES-AMP WAS REPLACED 3/27/2012 RO#521540 MILEAGE 69.044 ~|~THE MARK LEVINSON SOUND SYSTEM AMPLIFIER HAD INTERNAL OPEN CIRCUIT CAUSING NO AUDIO. ~|~74483 THE MARK LEVINSON SOUND ...
69048 MILES
DATE:
05/24/2012
REPAIR# 0528529
SERVICE: N/C
DESCRIPTION: N/C ~|~CHECK TIRE LIGHT ON---NO CHARGE---
69045 MILES
DATE:
03/30/2012
REPAIR# 0522233
SERVICE: USE CAR DETAIL FRONT LINE READY
DESCRIPTION: USE CAR DETAIL FRONT LINE READY ~|~USE CAR DETAIL FRONT LINE READY
69044 MILES
DATE:
03/27/2012
REPAIR# 0521540
SERVICE: CLIENT DECLINED COURTESY CHECK LIST.
DESCRIPTION: CLIENT DECLINED COURTESY CHECK LIST. ~|~CLIENT DECLINED COURTESY CHECK LIST.
SERVICE: REPLACED RADIO AMP ASSY
DESCRIPTION: REPLACED RADIO AMP ASSY ~|~CHECK AUDIO IS INOP, SOP IS IN ~|~AMP HAS INTERNAL FAULTY ~|~69044 AMP HAS INTERNAL FAULTY 40 LEXUSW CERT CONT#14611568 AUTH#VSA2MW9126 TOTAL$638.15 REPLACE RADIO AMP ASSY
68776 MILES
DATE:
03/24/2012
REPAIR# 0521082
SERVICE: REPAIR
DESCRIPTION: REPAIR ~|~CHECK AUDIO IS INOP, WILL NOT ADJUST WITH VOLUME ~|~SOP AMP ~|~68776 SOP AMP
68361 MILES
DATE:
03/17/2012
REPAIR# 0520223
SERVICE: DONE N/C
DESCRIPTION: DONE N/C ~|~CK BRAKES
SERVICE: REPLACED REAR SHOCKS
DESCRIPTION: REPLACED REAR SHOCKS ~|~REPLACE REAR SHOCKS ARE LEAKING ~|~REAR SHOCKS LEAKING ~|~68359 REAR SHOCKS LEAKING 481251A 70 LEXUS CONT#14611568 AUTH#VSA2MT3329 TOTAL$1345.90 REPLACE BOTH REAR SHOCKS
63937 MILES
DATE:
01/17/2012
REPAIR# 0510864
SERVICE: =LUBE OIL AND FILTER
DESCRIPTION: =LUBE OIL AND FILTER ~|~=LUBE OIL AND FILTER ~|~ ~|~63935 OIL CHANGE DONE
SERVICE: REPLACED FILTERS
DESCRIPTION: REPLACED FILTERS ~|~ENGIE AIR FILTER 2007 TUNDRA 5.7 PARTS ONLY NO LABOR ~|~ ~|~63935 DONE
SERVICE: REPLACED FLITERS
DESCRIPTION: REPLACED FLITERS ~|~FILTERS AC AND ENGIE PARTS ONLY NO LABOR ~|~ ~|~63935 DONE
SERVICE: ROTATE TIRES
DESCRIPTION: ROTATE TIRES ~|~ROTATE TIRES ~|~ ~|~63935 DONE
SERVICE: VEHICLE INSPECTION REPORT
DESCRIPTION: VEHICLE INSPECTION REPORT ~|~VEHICLE INSPECTION REPORT
59424 MILES
DATE:
10/31/2011
REPAIR# 0500135
SERVICE: BATTERY
DESCRIPTION: BATTERY ~|~CHECK BATTERY, CUSTOMER STATES VEHICLE HAD A HARD TIME STARTING. RO#446627 DATE 11/04/10 ~|~BATTERY FAILED LOAD TEST DURING INSPECTION DUE TO INTERNAL SHORT CIRCUIT ~|~59423 BATTERY FAILED LOAD TEST DURING INSPECTION DUE TO INTER...
SERVICE: COMB: BATTERY
DESCRIPTION:
58932 MILES
DATE:
10/18/2011
REPAIR# 0498382
SERVICE: 27 POINT INSPECTION
DESCRIPTION: 27 POINT INSPECTION ~|~27 POINT INSPECTION
SERVICE: DONE
DESCRIPTION: DONE ~|~RECOMMEND A/C FILTER BY NEXT SERVICE
56228 MILES
DATE:
09/13/2011
REPAIR# 0491924
DESCRIPTION: 27 POINT INSPECTION ~|~27 POINT INSPECTION ~|~ ~|~56226 DONE
SERVICE: =STATE INSP FOR 96 & CURRENT
DESCRIPTION: =STATE INSP FOR 96 & CURRENT ~|~=STATE INSP FOR 96 & CURRENT ~|~STATE ~|~56226 STATE 50 DONE
SERVICE: INSTRUMENT PANEL SUBASSY
DESCRIPTION: INSTRUMENT PANEL SUBASSY ~|~CUSTOMER STATES THE DASH IS CRACKING PLEASE CHECK SEE SCOTT ~|~DASH IS DEFORM. DUE BAD MATERIAL ~|~56226 DASH IS DEFORM. DUE BAD MATERIAL 550451 240 GOODWILL PER PAUL K, LCS OPCODE OP -CODE - T1/94 T2/16 PART # 5...
SERVICE: INTERIOR LIGHT BULB (ONE)
DESCRIPTION: INTERIOR LIGHT BULB (ONE) ~|~CUSTOMER STATES THE RIGHT VANITY MIRROR LIGHT IS INOP ~|~SUNVISOR LIGHT INOP.LIGHT BULB OPEN CIRCUIT ~|~56226 SUNVISOR LIGHT INOP.LIGHT BULB OPEN CIRCUIT 812021 20 T1/72 T2/71PART #90981-14014REPLACE SUNVISOR LI...
53879 MILES
DATE:
07/22/2011
REPAIR# 0485442
DESCRIPTION: =LUBE OIL AND FILTER ~|~=LUBE OIL AND FILTER,**** MATT SEE SCOTT*** ~|~ ~|~53879 30 OIL CHANGE DONE
48850 MILES
DATE:
03/24/2011
REPAIR# 0467908
SERVICE: DONE
DESCRIPTION: DONE ~|~REINSTAL SPARE TIRE UNDER VEHICLE ~|~ ~|~48850 REINSTALLED TIRE UNDER THE VEHICLE
48830 MILES
DATE:
03/10/2011
REPAIR# 0465824
SERVICE: CERTIFIED PRE-OWNED 1ST OIL CHANGE
DESCRIPTION: CERTIFIED PRE-OWNED 1ST OIL CHANGE ~|~CERTIFIED PRE-OWNED 1ST OIL CHANGE ~|~LOF ~|~48828 LOF 001011 30
43811 MILES
DATE:
11/11/2010
REPAIR# 0447914
SERVICE: 45K MILE SERVICE: LUBE OIL & FILTER, CK ALL FLUIDS, INSPECT AIR FLTR, A/C FLTR I
DESCRIPTION: 45K MILE SERVICE: LUBE OIL & FILTER, CK ALL FLUIDS, INSPECT AIR FLTR, A/C FLTR I ~|~45K MILE SERVICE: LUBE OIL & FILTER, CK ALL FLUIDS, INSPECT AIR FLTR, A/C FLTR IF APL. ROTATE TIRES. INSPECT BRAKES, COOLING SYS, EXHAUST SYS, TRANS...
SERVICE: =4 WHEEL ALIGNMENT
DESCRIPTION: =4 WHEEL ALIGNMENT ~|~=4 WHEEL ALIGNMENT
SERVICE: CERTIFIED PRE-OWNED PDI
DESCRIPTION: CERTIFIED PRE-OWNED PDI ~|~CERTIFIED PRE-OWNED PDI
SERVICE: DONE
DESCRIPTION: DONE ~|~COLORS OF HOU
43806 MILES
DATE:
11/04/2010
REPAIR# 0446627
SERVICE: BATTERY
DESCRIPTION: BATTERY ~|~BATTERY WAS REPLACED ON 6/30/10 MILES 42,728 RO#429558 ~|~SHORT CIRCUIT INSIDE THE BATTERY CELLS ~|~43806 SHORT CIRCUIT INSIDE THE BATTERY CELLS 190011A T1-71 T2-73 FP#28800-66021 60 RO#429558,42728,6/30/10 CODE A03P REPLACED THE...
DESCRIPTION:
SERVICE: DONE
DESCRIPTION: DONE ~|~TOW IN ~|~.
SERVICE: REPL ALTERNATOR
DESCRIPTION: REPL ALTERNATOR ~|~CK ALL IND LIGHTS CAME ON, DIED WHILE DRIVING ~|~. ~|~43806 271011 80 LEXUS CONTR#12547704 AUTH#VSA1ZW6720 TOTALCLAIM$616.35 REPLACED THE ALTERNATOR
DESCRIPTION: VEHICLE INSPECTION REPORT ~|~VEHICLE INSPECTION REPORT ~|~ ~|~43803 REPORT DONE
42728 MILES
DATE:
06/30/2010
REPAIR# 0429558
SERVICE: ADDITIONAL SERVICE REQUEST
DESCRIPTION: ADDITIONAL SERVICE REQUEST ~|~ADDITIONAL SERVICE REQUEST
SERVICE: BATTERY
DESCRIPTION: BATTERY ~|~HAD TO JUMP START CAR ~|~SHORT CIRCUIT INSIDE THE BATTERY CRCELLS ~|~42725 SHORT CIRCUIT INSIDE THE BATTERY CELLS 190011A T1-71 T2-73 FP#28800-66021 60 REPLACED THE BATTERY AND RE-INITIALIZED ALL SETTINGS
DESCRIPTION:
SERVICE: SEE LINE B
DESCRIPTION: SEE LINE B ~|~CUST STATES DASH LIGHTS COME ON AND OFF BY THEMSELVES ~|~. ~|~42725 CANNOT DUPLICATE AT THIS TIME,POSSIBLE BATTERY
41989 MILES
DATE:
06/23/2010
REPAIR# 0427797
DESCRIPTION: =LUBE OIL AND FILTER ~|~=LUBE OIL AND FILTER ~|~ ~|~41989
SERVICE: DONE
DESCRIPTION: DONE ~|~TIRE ROTATION
SERVICE: RESECURED LOOSE L.F BRAKE LINE
DESCRIPTION: RESECURED LOOSE L.F BRAKE LINE ~|~CK BRAKE AND VSC LIGHTS ARE ON ~|~ ~|~41989 LEFT FRONT BRAKE LINE LOOSE. DAIG.CHECK FOUND LEFT FRONT BRAKE LINE WAS LOOSE,TIGHTEN BRAKE LINE,TOP OFF BRAKE FLUID,BLEED SYSTEM,RETREIVE CODE,AND RETESTED VEHIC...
SERVICE: SUBLET
DESCRIPTION: SUBLET ~|~REPAIR WHEEL DAMAGED BY BRAKE FLUID
39072 MILES
DATE:
12/19/2009
REPAIR# 0401198
DESCRIPTION: CERTIFIED PRE-OWNED 1ST OIL CHANGE ~|~CERTIFIED PRE-OWNED 1ST OIL CHANGE ~|~.
SERVICE: NO PROBLEM FOUND
DESCRIPTION: NO PROBLEM FOUND ~|~CK HESITATION ON ACCELERATION
SERVICE: NORMAL WHEN AC CYCLES ON & OFF
DESCRIPTION: NORMAL WHEN AC CYCLES ON & OFF ~|~CK RPMS MOVE AT A STOP
SERVICE: NORMAL WHEN COLD
DESCRIPTION: NORMAL WHEN COLD ~|~CK HIGH IDLE ON INITIAL START UP
SERVICE: NORMAL WHEN SHIFTING GEARS
DESCRIPTION: NORMAL WHEN SHIFTING GEARS ~|~CK RPM'S DROP SUDDENLY WHEN DRIVING AT A CONSTANT SPEED ON HWY
SERVICE: OK @ THIS TIME
DESCRIPTION: OK @ THIS TIME ~|~CK THUMP SENSATION WHEN COMING TO A STOP
SERVICE: UNABLE TO DUPLICATE
DESCRIPTION: UNABLE TO DUPLICATE ~|~CK SQUEAK NOISE FROM REAR
36796 MILES
DATE:
08/29/2009
REPAIR# 0384700
SERVICE: ** INSTALL 4 TIRES AND BALANCE**
DESCRIPTION: ** INSTALL 4 TIRES AND BALANCE** ~|~** INSTALL 4 TIRES AND BALANCE**
SERVICE: 35K MILE SERVICE: LUBE OIL & FILTER, CK ALL FLUIDS, INSPECT AIR FILTER, INSPECT
DESCRIPTION: 35K MILE SERVICE: LUBE OIL & FILTER, CK ALL FLUIDS, INSPECT AIR FILTER, INSPECT ~|~35K MILE SERVICE: LUBE OIL & FILTER, CK ALL FLUIDS, REPLACE AIR FILTER, INSPECT A/C FILTER. ROTATE TIRES. INSPECT BRAKES, BODY INSP. ROAD TEST VEH.
SERVICE: =FRONT BRAKE REPAIR
DESCRIPTION: =FRONT BRAKE REPAIR ~|~=FRONT BRAKE REPAIR
SERVICE: DONE
DESCRIPTION: DONE ~|~REPLACE A/C FILTER,WIPER REFILLS,REPLACE RIGHT SIDE RUNNING BOARDDONE ~|~SET OF FLOORMATS,4 LUG NUTSDONE ~|~VENDORS
29588 MILES
DATE:
11/28/2008
REPAIR# 0346295
SERVICE: 30K MILE SERVICE: LUBE OIL & FILTER, CK ALL FLUIDS, R&R AIR FLTR, A/C FLTR R & R
DESCRIPTION: 30K MILE SERVICE: LUBE OIL & FILTER, CK ALL FLUIDS, R&R AIR FLTR, A/C FLTR R & R ~|~30K MILE SERVICE: LUBE OIL & FILTER, CK ALL FLUIDS, R&R AIR FLTR, A/C FLTR R & R IF APL. FLUSH BRAKE SYSTEM. ROTATE TIRES. INSPECT B...
SERVICE: DONE
DESCRIPTION: DONE ~|~REPLACE FITLERS AND INSERTSDONE ~|~EST ON REAR BUMPER
SERVICE: PLUG TIRE RIGHT REAR
DESCRIPTION: PLUG TIRE RIGHT REAR ~|~CK RIGHT FRONT TIRE HAS SLOW LEAK
17627 MILES
DATE:
12/12/2007
REPAIR# 0294997
SERVICE: 15K MILE SERVICE:*FREE OIL & FILTER* LUBE OIL & FILTER, CK ALL FLUIDS, INSPECT A
DESCRIPTION: 15K MILE SERVICE:*FREE OIL & FILTER* LUBE OIL & FILTER, CK ALL FLUIDS, INSPECT A ~|~15K MILE SERVICE:*FREE OIL & FILTER* LUBE OIL & FILTER, CK ALL FLUIDS, INSPECT AIR FLTR, A/C FLTR IF APL. ROTATE TIRES. INSPECT BRAKES, COOL...
SERVICE: =CUSTOMER CARE OIL CHANGE
DESCRIPTION: =CUSTOMER CARE OIL CHANGE ~|~=CUSTOMER CARE OIL CHANGE
SERVICE: COMB: OPPOSITE SIDE
DESCRIPTION:
SERVICE: DONE
DESCRIPTION: DONE ~|~REPLACE AIR, AC FILTERS AND WIPER INSERTS
SERVICE: F.DSC 1-SD (ON-VEH)
DESCRIPTION: F.DSC 1-SD (ON-VEH) ~|~CK VIBRATION WHILE BRAKING ~|~EXCESSIVE HEAT BUILD UP ON THE ROTORS CAUSING WARPAGE ~|~GRIND FRONT ROTORS AND TEST DRIVE
SERVICE: FRT DR LOCK ASSY 1-SIDE
DESCRIPTION: FRT DR LOCK ASSY 1-SIDE ~|~CK DRIVERS DOOR LOCK INOP ~|~OPEN CIRCUIT INSIDE DOOR LOCK ACTUATOR ~|~REPLACED THE DOOR LOCK ACTUATOR
SERVICE: REAR DRIVESHAFT CLUNK/THUMP NOISE 03-07 GX470
DESCRIPTION: REAR DRIVESHAFT CLUNK/THUMP NOISE 03-07 GX470 ~|~CK THUMP SENSATION WHEN COMING TO A STOP ~|~LACK OF LUBRICANT INSIDE DRAFT SPLINES ~|~REPLACED THE DRIVESHAFT AND CONTROL ARMS DL002- 07
17480 MILES
DATE:
12/07/2007
REPAIR# 0294512
SERVICE: NO WORK DONE
DESCRIPTION: NO WORK DONE ~|~CK DRIVERS DOOR LOCK INOP
SERVICE: NO WORK DONE WILL RESCHEDULE FOR 15K
DESCRIPTION: NO WORK DONE WILL RESCHEDULE FOR 15K ~|~=CUSTOMER CARE OIL CHANGE
6172 MILES
DATE:
01/31/2007
REPAIR# 0250614
SERVICE: 5,000 MILE SERVICE
DESCRIPTION: 5,000 MILE SERVICE ~|~=5K MILE SERVICE:LUBE OIL & FLTR,CK ALL FLUIDS,INSPCT AIR FLTR,INSPCT BRAKES,ROTATE TIRES,ROAD TST VEH ~|~MT
8 MILES
DATE:
11/11/2006
REPAIR# 0239925
SERVICE: LEXUS PERSONALIZED SETTINGS
DESCRIPTION: LEXUS PERSONALIZED SETTINGS ~|~LEXUS PERSONALIZED SETTINGS ~|~MT
7 MILES
DATE:
07/28/2006
REPAIR# 0225943
SERVICE: =NEW CAR STATE 2 YEAR
DESCRIPTION: =NEW CAR STATE 2 YEAR ~|~=NEW CAR STATE 2 YEAR
SERVICE: FRONT LINE WASH PDI
DESCRIPTION: FRONT LINE WASH PDI ~|~FRONT LINE WASH PDI
SERVICE: PRE-DELIVERY SERVICE FOR USA ALL ALTITUDES
DESCRIPTION: PRE-DELIVERY SERVICE FOR USA ALL ALTITUDES ~|~PRE-DELIVERY SERVICE FOR USA ALL ALTITUDES ~|~PDI
As a local Houstonian whose been trying to find the right GX for months now, get outta here! JK... Is this one from uptown motors? I was looking at that one but it was slightly more than what I wanted to spend, glad it found a home in this community. Did you have the dealer send you pics of the underbelly to check for rust? I was just looking at one at West Houston Volkswagen last week that had an abnormal amount of rust on the underside despite being in Houston it's whole life, and went I went for a test drive it through a check engine light.
Just went to uwharrie with ours, picked it up about 2 months ago from a family in Matthews, NC, and starting a slow build, just steps removed and all terrains for now. Was blown away by how well this crawled... And even better the expressions on big jeep owners faces as we went along.
So good to have all the records for yours, reach out when you start your build
That's the one! And yeah, it was more than I was looking to spend too, but the timing is right as I have a few potential buyers already lined up and eager to purchase my current car. After months and months of searching with a pretty specific wants list, it was time to make a move. Now just gotta figure out how to get it to me here in Charlotte! And yes, I did ask for and receive pictures of the underside, besides being a bit dirty it looked clean and clear of any rust.
Beautiful rig! And I definitely will, once I sell my current project this one will take off fast and it'll be nice to meet other owners in the area. I never fully got over my old TT FJ Cruiser, so it's good to be back.
