I've had a case of the grrrrrrs ever since I put on a 2.5" OME (mediums) and 285 Revos. It's been almost 30k miles now, with over 20k miles with the front driveshaft out to reduce the harmonics. I tried a bunch of stuff; new driveshafts, measured angles, rotated and balanced tires using a Road Force machine. Nothing I did seemed to help.
About 2k miles ago I needed to tow a car on a flatbed trailer for about 200 miles. Total load was over 5000lb. When I took off the trailer, for the first time, I had a grrrrr reduction. It was unmistakeable. I put a couple hundred miles on the truck, and with no change, I re-installed the front driveshaft (for the first time in over 20k miles). I can still feel a vibration at where the grrrrrrs used to begin, but it is reduced and the harmonic grrrrrrs are gone. It's remained constant for over 2k miles now. I'm due for a tire rotation soon, so I'm interested to see if things get better or worse. I'm almost hesitant to rotate them since it's been so long since I've had two driveshafts.
I haven't been able to wheel the truck where I live since I've put the OMEs on. I wonder if the springs needed to get compressed to help drivetrain alignment.
All of this is just an observation I wanted to pass on to those who have the same harmonic problem.
