Searched for beep, door beep, beeping and found threads about a rapid beeping and an issue with the moon roof open. This is different.
This morning I tried the stereo and it didn't work properly, it was very muffled. When I turn off the ignition and open the door, you get that solid beep. When I take the key out of the ignition, I get the same solid beep but it's softer and changes pitch slightly.
I played around with electrical switches and when I turned the rear heater on and off, the radio started working again. The strange beeping noise is still there.
Not an emergency because everything works, just wondering if I have some issue that will be a problem down the road.
