Poser's T-Case Saver
Cruiserdrew
On the way there
Sacramento, CA
Props to Poser on this...
I bought one of these from Steve at http://www.lcr4wd.com/ about 6 months ago and got a chance to install this afternoon. I had read previously that you had to pull the transmission hump to install this, but it looked like there was plenty of room, so I dived in.
To loosen the 5 bolts on the cover on the t-case is a breeze with a gear wrench. It took maybe 10 minutes to pull all 5. You just reach in there with the gear wrench and work each out in turn. The upper mounting bolt on the t-case is right there, but sort of partly behind the rear input shaft cover. I got that with a wobble extension. The new plate fit perfectly with no fitting needed. I installed the 5 small bolts first loosly, then the main big bolt on the t-case. The most time consuming part of the job was buying a new bolt at the hardware store that was 1/2 inch longer (I have an SM420 with Warden plate). If you had a OEM set-up, I think you could get by with the OEM bolt. I then tightend that bolt barely snug, tightend the 5 bolts in the t-case, and finally the main bolt that holds the t-case to the transmission.
The fit was perfect with no adjustments needed. THis adds significant strength at the critical weak spot of the Toyota 1 piece t-case. Given the excellent fit, low price, and ease of install, I'm going to give this t-case saver a very strong recomendation, especially if you have a weaker 3 speed case. My only nit to pick with this was the 13mm heads on the supplied t-case bolts. I prefer to stick with the JIS 12mm head bolts where possible, but Steve ships high grade (10.9) bolts so it's a minor thing. Two thumbs up-you should buy one if Poser has any left. Here is a lame picture-it's hard to get your camera in there:
All of Poser's schtuff is 1st Class. He does not put anything out there that has not been tried and tested. Drew, I see that you let parts age before installing them.....holds down the "shrink factor";)
Ed
Ed
I've been working on my 80 and 60 all this past winter, and the 40 has been ignored in the garage. Since Rubithon is just around the corner, it was time to work on the truck. I just installed Poly Performance axle shafts in the rear as well-those were aged about 4 months before install! The 40 still needs a tune up/valve adjustment before Rubithon, but then I'm ready to go.
