por15
North Idaho
Anyone ever use por15 putty. I have used it to fix a fuel tank, but does anyone know if it can be used to fix a radiator top tank? I am worried about the pressure, my tank is leaking at the seam.
I'd say no. Based on that it needs to be pretty rough to get the por to stick properly.
Now how is this diesel tech??? Gonna move this but I will leave a redirect. :)
Stick you in the 40 series section, since this is on a 40.
db,
If you aren't going to have it soldered, try JB Weld for something like that.
Personally I think if you arn't going to drain it, blast it, weld it, fiberglass the s*** out of it and paint it, then get a good used tank from a place like G&S, a half assed fix will not last long with a fuel tank!
