POR-15 and bolts and nuts
Newport, NC
I was thinking about putting POR-15 on my frame and was wondering if I go over the bolts and nuts will I have any problems down the road in removing them. Havent really seen POR-15 but heard it hardens up pretty good, does it crack if you remove bolts later? Thanks in advance for any feedback.
I did my frame with the black stuff. Later I had to remove some bolts and it did crack and remove some of the POR15 around the bolt. But after I replaced the bolts I just put a little POR15 touch up on them. no worries.
yeah no problem. POR-15 is really thick and hard to spray well but is pretty bulletproof and prep is basically jut knocking off large surface rust and dirt
