Pop you back window before......
Sudbury Ontario Canada
......this happens to your hatch!
My cruiser has spent most of its life in Northern Ontario Canada. You can see the results of the road salt. The rust bubbles that were visible around the edges of my window seal were 10x as bad once the window was removed.
I picked up a hatch from a fellow mudder and painted it to match.
Didnt take any pics while swapping hatches but it was pretty straight forward.
To remove the old hatch we stripped everything I needed off of the old one and transferred it to the new hatch. Then we fished out the wiring that runs down the ds hatch pillar and let it hang. We undid the hatch struts at the hatch and let those hang. Removed the 4 bolts at the hinges and the hatch was off.
To remove the rear window we just used our fingers to pry up the window seal from the inside of the hatch. Really simple and the window popped out w/o any drama. We removed the seal from the window and cleaned it. Lots of flaky rust stuck to it.
Next, we used urethane to secure the seal to the glass. To install the window into the hatch we ran another bead of urethane around the outside of the seal then slid the window and seal into the top part of the hatch. We held the hatch upside down and used a plastic bicycle tire lever to get the rest of the seal over the rim of the hatch.
The install of the hatch was the reverse of removal.
Hint: A bicycle brake cable worked great when fishing the wires back down the hatch pillar. We fished it through, tied/taped it to the wiring and pulled everything through.
After minimal adjustment this is the final result.
Hope this helps someone out.
D
Thanks.
Not too bad for a garage jobbie using spray bombs. Up close the paint does have orange peel but it looks better than I thought it would.
My wiper sits where its supposed to now too which is cool.
D
Nice job!
Looks like you made out for a lot less than me! I tried like hell to source a used one for a decent price, but had no time to wait.
Looks great!:cheers:
