Anyone running these? Worth the money ($450) - long term investment. I've only broken a rear once, but after a few years of either breaking pinions, birfields, hub studs, and other stuff - I'm trying to go as bulletproof as possible. Tired of wrenching on the trail . Any opinions welcome.
i think there a sweet idea the only downfall i could possibly see is your moving your breaking point further up the driveline... do you still have a coarse spline pinion? if your not breaking the axle - what is the next thing to break?
and doesn't the heat treating they use soften the material slightly so they can "flex" instead of just shearing off... ( in relation to the longfeilds) which the downside of those was the they wear out quicker then stock birfs but i think you should only be worried about that if your in 4wd 24/7-365... so would a vehicle that is constantly atleast in rear wheel drive under those same conditions as was said about the heat treated chromo longs? ...
this is all speculation i don't really have any exp. with the product
I ran them all last summer. It's an excellent product in my opinion. So good, in fact, I stopped carrying spare axles and saved 50 pounds. I have the axles out of the truck right now, and there is no wear on the bearing area. I don't think that's a major issue unless you drive 25k miles per year.
One thing about mounting-the buttons on the diff end are a couple of thousandths thicker than stock, and you must run the thinnest c-clip with an airlocker. The space block just barely fits with the thin c-clips. The alternative would be to touch the end with a grinder, but I was hesitant to do that.
These are very nice, and supposedly have never been broken. It's a very good product and less expensive than new ones from Toyota.
Sounds good so far. I only wheel hard a few weeks a year, and only drive on the street about a 100 miles per month in nice weather. I'm running 30 spline longs in the front, long travel front ds, and a mini truck cardan in the rear (both HAD fabbed), but still have course spline pinions (of which I've already broken 3 - one sprung under, and 2 sprung over with an insufficient trackbar). Building up a killer traction bar this week - will have to post pics - it's an unusual concept.
I run either a lock right or no slip in the rear (one is a spare, but always seems like they get switched out once in a while). I would be worried about getting the pin in - as it's already a pain with the no slip - but nothing that I couldn't resolve in the shop during the install.
