Polishing my crank?
Kansastitty
My crankshaft is within tolerances to just put a new set of STD main and rod bearings. It is not scored or particularly fawked, but should I go ahead and have it polished. I'm in waaaay too deep to try and save a few bucks now.
Ed
Without seeing it, I would say go ahead and do it. I have done my own when it is not too bad. I get emory cloth (I want to say it was 600 grit) and polish each journal.
Ed - There's probably only one guy in town that grinds crankshafts and all the engine rebuilders use him for cranks. If you can find that guy, you can probably get the crankshaft polished for $30 or so. He probably doesn't generally deal with the public so he may not be inclined to do the work, but it's worth a try.
Good Luck,
James
I closely inspected the crank and it is not scored. Motor only had about 90K on it, so I think I'll go the emory cloth route. I've already got the OEM std bearings.
Thanks,
Ed
