So the SAS itch in my crotch will not go away and I plan to unload my rear axle on Joe and pick up Lc nuts fj60 axles hopefully this weekend. I need a place to organize my thoughts and ask dumb questions with a lot of off topic gay banter, so I'll make a thread. The plan is to build the axles this summer and stock pile some parts and swap this truck this winter. The plan is:
Flipped fj 60 front
It will probably stay open for a bit until I can get some rcvs. I will be re using my tundra brakes on it as well.
Chop the entire front of the frame off since it will be less work in the long run than plating this rusty POS and allow me to keep it low and not have to notch s*** for steering and axle clearence.
Shackles forward with waggy leafs with a leaf added to them for no lift.
37s some day, but it may be low enough to shakedown with my 33s. Hopefully.one of you guys with 37" pbr's will be sick of them by next spring....
F150 steering box because hydro assist looks like a PITA, only problem is the box is huge and forward swing which may get on the way..... Or may help...
So what are my steering options? Supposidly the axle already has histeer arms, and john is telling me to go low steer...
The legendary ZUK is doing the exact same swap on his taco, lots of cool tech in here:
http://www.yotatech.com/f152/2001-tacoma-sas-costs-t100-oilpan-considerations-283930/index6.html
What am I missing besides coilovers, air bumps, links and a tube frame?
Flipped fj 60 front
