Ordered up some sliders a while back from white knuckle - DS side went on fine but PS side was a problem. Turned out the PO had some work done on the exhaust which resulted in the catalytic converter being shifted 1.5 inches forward(ish).
So - if you check the picture out the middle slider arm now actually has the catalytic converter resting on it - which is making for some funky vibrations through the car - got a quote of about 80 bucks to move the tandem converter setup so the gap in between the front and rear catalytic converter lines up with the slider arm.
My question - is the orientation of the catalytic converter also wrong? its seems that it would work way better if the whole cat was rotated 90 degrees - is that what the oem setup is supposed to be like?
thanks in advance!
thanks in advance!
