plug thread size?
I have read several threads recently about the problem of the seal between the transmission and the transfer case. In retrospect, I am convinced that my 1976 FJ40 has this disease. A while back, a local garage "checked" the transmission and TC and there was a tsunami of oil coming out of the transmission. They stuffed the plug back in and their diagnosis was everything was "fine." I have removed the filler plug on the TC and the fluid level is low. I am hesitant to remove the filler plug on the transmission in anticipation of the mess that will be created. I would prefer to fix it and change out the fluid. I would like to fabricate the well-known bypass and that will require going to town and looking around. I have the TC oil filler plug and my question is: ARE THE FILLER PLUGS FOR THE TRANSMISSION AND TC THE SAME SIZE THREAD, etc. ? If they are, I can just buy several tomorrow along with fittings. Any other tips would be appreciated (power steering grade hose perhaps?)
When I am not on dial up, I will search...I posted up a list of fittings, sizes and part numbers for the pieces that you can get to make one of these.....or just call MAF and get one on the way..
Good luck!
-Steve
The filler plugs ARE interchangable/same size thread on three speed setups. I'm not certain about 4 speed.
yes, they are the same size on my four speed and TC, I just drilled holes in the plugs that were there, and tapped them for barbed fittings, seemed like a good idea at the time, saves you a couple of bucks if your time is worth nothing.
