Please, Real time quick help about oil change
Opelika, AL
I was changing my oil today because I have a long trip planned tomorrow. I flushed my engine with Amsoil flush. When I took my drain plug out I noticed that the rubber grommet was ate up. Where is an acceptable place to get a new one at 6:00pm my time?
OEM Oil drain plug uses a crush washer, not a rubber grommet. Local auto store for a generic crush washer to fit the metric drain plug?
Thanks for the replies and the PM Bear80. I'm thinking this rubber gasket was put on by the previous owner. Everybody has said, ".........no rubber gasket.....". Even the people in my local group.
I'll have to put my trip on hold for an hour so I can get one from the Toyota dealership if they have one in stock. If not I'll try the one from autozone along with the permatex around the outside.
FWIW, the OEM drain plug gaskets (diffs, TCase, AT, and oil), per the FSM, are one time use deals. Can't remember the cost but they are like $1 something IIRC. They are of a crushable design.
When I first changed the oil in my LX I noticed that it was apparent the gasket had be reused numerous times. I just picked up a package of gaskets from Checker that had various sizes in the package and ran that until the next oil change. No drips, no problems. Then, on my next order to CDan I just added a 1/2 dozen or so of the gaskets to have on hand.
Don't overthink it too much :) - heck, IIRC even IdahoDoug mentioned in a post that he has been known to "reuse" the gasket more than once from time to time.
Trip was cancelled. I did go to Toyota and get the crush washer that was supposed to be on there. It had rubber on both sides of it. The washer had a convex shape on one side and concave on the other. This I assume was the crush part because as you tighten, the washer flattens out or crushes.:idea:
