Please help
Las Vegas, NV
I flushed the auto fluid today and found the small cable..
Does anybody know what these small cable for?
And perhaps do you know where it connect to? I spent an hours to looked but seems no where and no clue where it connect to.
The blue silicone firewall hose was replaced by the PO.
The small cable appears to be the heat control cable that goes from your temp control slider to your heater valve just behind your hand in the photo. Do you have heat? Have someone move the heat control slider while you watch the cable; it should move. Easy to reattach onto the little lever found on the valve. BTW; silicone hoses (seen in the background of your photo) are better held to metal pipes with Constant Torque (CT) clamps available at NAPA. Silicone does not "stick" to metal like rubber hoses, so can leak and/or even pop off if the wrong type clamp is used IMO. The only time I had a hose pop off was many years ago; I painted a new radiator including the lower radiator pipe with a very nice and very slick coat of engine paint and then put the hose back on with the OEM clamp; it lasted about 3 miles before it popped off. Slick is not good when it comes to coolant hoses and their connections.
The small cable appears to be the heat control cable that goes from your temp control slider to your heater valve just behind your hand in the photo. Do you have heat? Have someone move the heat control slider while you watch the cable; it should move. Easy to reattach. BTW; silicone hoses are better held to metal pipes with Constant Torque (CT) clamps available at NAPA. Silicone does not "stick" to metal like rubber hoses, so can leak and/or even pop off if the wrong type clamp is used IMO. The only time I had a hose pop off was many years ago; I painted the lower radiator pipe of my new radiator with a very nice slick coat of engine paint and then put on the OEM clamp; it lasted about 3 miles before it popped off. Slick is not good when it comes to coolant hoses.
x2.
Yes I do have heater, no problem.
Pardon me for being stupid here, when you said easy to reattach onto the little lever found on the valve.I cant find the little lever.
Also I was looking thru the whole pages FSM seems no where I can find those little lever.
If anyone of you may have pic to show would be very helpful and appreciated.
Many thanks.
This Is what it looks like on my 1HDT. Maybe the po took it off thinking that you did not need it.
JerryLX450; ditto; there should be a ~2x2 inch black plastic box (heater valve) sandwiched between two heater hose sections up against the top central firewall behind where your hand is in the photo. If not there or not sure, you could post a photo of the top center section of your firewall above the valve cover to show us what is up. Maybe the previous owner ripped it out??
Looks like you got it! The cable should be adjusted to make sure when the temp control slider is full cold (in the blue) that the valve is all the way against the stop at the other end of the little lever where the cable attaches (looks like it is in the photo). Now you should have (better) heat (control).
