1996 LX-450. Spins but won't start. Every once in awhile it will turn cough and turn over a bit then notihing. After 1/2 a can of starter fluid it will finally turn over and then run perfectly.
After this I can shut it down and it will restart and have no problems. It will do fine for a long time.
No CEL when ignition is in on position, however, I don't know if I've ever seen the CEL on this vehicle.
Changed out EFI relay and the socket tests good voltage so the EFI doesn't seem to be a problem.
I recently did some wiring work so the batteries have been connected and disconnected somewhat regularly, but this particular problem has only occured twice in the past three or four months.
Both times it happened it was damp and had rained for several days. The plug wires and distributor look good however. I didn't check for spark because the vehicle seemed to kick and try to turn over as I was cranking it.
LX-450 OME 3" Snorkle, ARB Bullbar w/ 12,000 Winch, Dual Batteries, Yakima Box
Thanks!!
John
Thanks!!
John
