Please Help - Not Starting
Plano, TX
After multiple hours sniffing around trying to fix a starting issue and multplie calls to Jon Held (Big Thanks!) and a call to the man from Sierra Vista (Thanks John!) I have now discovered something very interesting...I went out and was double checking the B+ terminal and saw that now it had power to it...hmm hooked back up the coil and "with a mighty roar the old gal came to life" ran it for 5 minutes everything seemed fine. Turned it off and it wouldn't start again.
Here what I noticed. When I turned to key to "on" and it started all the dash lights (ce, etc.) were lit up and B+ had power. The next time I went to start it the only thing that lit was the seatbelt light and there was no power to B+.
Please tell me that it can be something besides the ECU that would cause this!!!
Already replaced the EFI Main Relay, was clicking on and off after replacement.
Things to look for:
* Bad or corroded battery ground.
* Bad fusible link
* Loose connection(s) at the battery
* Bad battery
-B-
