PLEASE HELP: 1994 No start
Charlotte, NC
Hey guys, I've got an issue that I'm trying to track down. Currently my truck will not start. Cranks beautifully but won't turn over. I'm 90% sure its a fuel system related issue and let me tell you why and if you could point me in the correct direction of where to go from here that would be great.
At first i started shotgun replacing parts trying to narrow it down. So far I've I've replaced the alternator, fusible link ( mine was old and brittle anyway so good to do), EFI main relay, fuel pump relay, and charcoal canister. none of these changed the symptoms.
Today while i was giving it a go again I decided to do the fuel pump test at the OBD1 port because i was thinking maybe the fuel pump was dead and that was next on my list of parts to replace. Low and behold I heard the fuel pump wizzing away and decided to crank the car to give it a go and it fired right up!
Next thing is what points me directly to the fuel system. When i pull the paperclip from the diagnostic port it shuts off.
So far this is what I've tracked down. Bench tested the open circuit relay and it passed. So that's good, I know that the fuel pump relay is new so i shouldn't have to worry about that ( I know i should bench test this too just to make sure). I tried bypassing the fuel pump resistor and im not sure if i did that right.( i basically just plugged my paperclip into the connector clip and though that would do the trick ( if not can someone please tell me how to properly bypass the resistor) bonus points for pictures because I'm a very visual learner.
So now i don't know what else to do or check, any and all suggestions are appreciated!
Please help me I wanted to go wheeling tomorrow!!!!!
Glad you are starting to diagnose instead of throwing more parts at it. 👍
Is the circuit opening relay closing (click) when the starter is activated?
Sorry my phone hasn’t been being funky all day so I haven’t been able to respond. There is definitely an audible click
Bump really need to get this straightened out!
