over the last week, i knew i had a leaky wheel cylinder. well, pulling into the garage on sunday was the point where i needed to do something about it. luckily there was enough junk in there to prevent any damage! the pedal went to the floor twice before i knew what was going on.
anyway, my father and i pulled the wheel and tire off of the side(rear passenger side)that was leaking. it was a mess. fluid was everywhere, and both of the cylinders were locked up. we serviced the cylinders, and applied new brake shoes. we thought we pull the other side(rear driver side) off and see if it needed new shoes. i am glad we checked because both of those cylinders were froze up. so, we serviced them and put new shoes on too.
after all of that, we adjusted the shoes and blead the lines. it still took 3 pumps to build any pressure. so, we decided to pull the master cylinder off to clean it and make sure it was not bad. there was some gunk in there, but nothing too bad. we bolted it back on, and still nothing.
i tested it out on a gravel road, and after 3 pumps i could lock up the front tires. the back tires would never lock up. the first two pumps went right to the floor. we did not bleed it again after re-installing the master cylinder. i know that may very well be my problem. but, it has been doing this consistantly even after we blead them the first time.
a little background to the brake problems: this landcruiser has been sitting idle for about a year and a half. we rebuilt the engine (kept the F) and have been doing some here and there stuff. now, my daughter is just getting old enough to enjoy riding in it. she even tries to call it julio! i will also add disc brakes to it next week if all goes well with this problem. it is the set from cruiserparts.net.
thanks for any help. jeff
