Plastic fitting screws
They aren't really screws, they are plastic fittings that hold the plastic floor foot steps in place on the floor of the second row of seats. They are jut inside the rear doors.
Thanks.
Thanks.
Click the link @NLXTACY posted...
They are still available from the dealer, if you wanted OEM.
Wits End ones work great! Just sayin’......
No slight meant to Joey, his stuff is top notch. The OEM plugs were designed to allow the OEM harness to sit below the step. If you put more stuff in there, you definitely need the longer screws.
No offense taken. I didn’t originally make these to replace OEM, that would be dumb. I did them because not all the colors are available AND I needed extended step nuts to clear the wiring and Dynamat that I put in the truck.
